I just tried getting my telem working on my Jeti. After going through the set up as per the wilki page, my Jeti will not see the telem Any thoughts.
Jeti
you have to enable Link-Live feature in your ESC to make it work (and also to enable Telemetry in the Spirit Settings)
It should not suck any voltage normally, otherwise it would be very hot.
Is the Link-Live enabled?
Can you try to decrease the BEC voltage to 6.6V too (just for try)?
In any way it is really strange. Is your wiring special in some way?
Are you using external BEC, buffer pack or similar electronics?
Do you have a multimeter? If so, you can measure resistance between the wires - when the cable is disconnected. Between signal and red wire, there should be 1kOhm. Between other, there should be nothing.
Thanks!
Yes, it should be 10kOhm - sorry for confusion. So the cable is OK fortunately.
So without the cable, when you connect the throttle cable into the AUX port, it is working. With cable it does not work.
Could you try to decrease General - Throttle/Governor - Throttle Range - Min. by 10 - 50us to see if it makes a difference?
Can you check when the unit was bought? Unfortunately some of the very first units have compatibility issue with the CC telemetry. But we are able to fix it for free.
Please try to decrease the value to 1060us.
In any way it looks like the unit is from the first batch
Have you other unit that was bought few months later?
So that you can try it with a newer unit.
If this will be the case, we can fix the problem in one day and for free. Unfortunately we will need the unit here.
