SYS -> Telemetry Port (Graupner GR-18 Channel 9)
CH0
CH1 -> Servo
CH2 -> Servo
CH3 -> Servo
CH4 -> Servo
AUX2
AUX1 -> External BEC (red/black)?
RUD -> SUMD Port RX (Graupner GR-18 Channel 6)
ELE/PIT/AIL
The Hobbywing has 3 Connectors (see attachment): -+R, -+S, -+P. Since its an Opto i'm not sure which one belongs where. Do i only have to attach (3) Throttle Signal Cable to the Spirit Pro? Do i need to plug all 3 pins from the Throttle? Should it go to AUX1 and therefore move the external BEC to AUX2?
To connect the telemetry from the HW -> Spirit this cable should be used: http://manual.spirit-system.com/index.p ... _Telemetry. Can i attached it using a Y cable on the Programming Port since im running the ESC using the fan?
Is it correct that i don't need the -+R port since it's an Opto (no BEC output) and the RPM signal is not used (->telemetry...)
Many questions
Thanks for your help in advance
