Info how work SPM4649T Telemetry
Yes, this is normal with this ESC. You can get additional telemetry data by connecting a wire directly to the SPM4649T receiver.
Thanks ZeXx86ZeXx86 wrote:Yes, this is normal with this ESC. You can get additional telemetry data by connecting a wire directly to the SPM4649T receiver.
what do you mean by wire directly?where , in which port on spm4649? other additional sensors? where you add cables to spm 4649 t? I have only one free port now on spm 4649, the jst 2 poles/where u can connect laps/V batt
Yes, this is what I have meant.
Ok Perfect, then I feel confirmed that for now on the 2.4.3 firmware without additional sensors but only with the 4649 spm, and with compatible ESC, the only data you can receive are:
1) Rpm (from esc)
2) Volt (from esc)
3) Temp Fet (from Esc)
The motor data 0.0A and 0% output are always stopped.
1) Rpm (from esc)
2) Volt (from esc)
Yes, please see this table:
http://manual.spirit-system.com/index.p ... ted_models
Perfect now all clear!!!
Last question the gps when it will be released? and if possible one day find and where quality cables already crimped Jr / futaba to jst, I ask why on heli small size, the additional links plug/conversion take up space, when use microspirit.
there is link my video
of my heli (OLD TREX 250 SE)working perfectly with microspirit both mechanical flybar, and dfc (now) AS PHOTOS
https://www.youtube.com/watch?v=7O5oVNSFjhw
