rleap
If I am using a DSMX satellite and bind using the dsm2 port... What is the difference and what are the results.... Using the micro spirit and a dx9...
LogoX2
If your using a DSMX Sat. then you want your bind plug in the E/P/A port, this will bind the Spirit
in DSMX
rleap
Yes I know the stated correct binding method...
My question was what happens if I bind it using the dsm2 socket... And what are the results...
- Site Admin
if should bind and work with DSM2 protocol.
It is likely you will not notice anything wrong, but it is recommended to use DSMX.
