Binding Dsm2 vs dsmx
rleap
If I am using a DSMX satellite and bind using the dsm2 port... What is the difference and what are the results.... Using the micro spirit and a dx9...
LogoX2
If your using a DSMX Sat. then you want your bind plug in the E/P/A port, this will bind the Spirit
in DSMX
rleap
Yes I know the stated correct binding method...
My question was what happens if I bind it using the dsm2 socket... And what are the results...
if should bind and work with DSM2 protocol.
It is likely you will not notice anything wrong, but it is recommended to use DSMX.
