[SOLVED] Spirit Pro stopped working
Vicente_cgn
ZeXx86 wrote:Hello,
the values are looking good. The behavior is very interesting as if receiver is connected somehow improperly or sending strange data.
Is it possible to not connect receiver?
Could you please let me know if you can see serial number in the Connection tab - is the last digit "....-10"?
Good morning,
I did another test: with only Slave-BEC in AUX1 and the Nick-Servo (CH2) connected the unit stays in "sleep-mode" after booting.
I couldn't get a connection via USB so I added the receiver (RUD-Port and AIL-Pin). This way I copuld get it out of "sleep mode".
Interesting detail: while giving nick-input the unit stays awake even if the input doesn't change, if I activate the rescue mode it goes back to sleep after 1-2 seconds and I get the following message from the usb-connection:
So, at last, here's the serial number of the device:
I'm afraid there's nothing more I can do and the the unit packed and send back to you!?
Can you perhaps tell me when I will have it back approximately? I'm just asking because that's the last part I need to get my new TDF up in the air. :)
Greetings,
Thomas
Well, done - it should be possible to fix the problem remotely. It look like for some reason there is corrupted internal memory, but it can be fixed quite easily.
Did you send the unit already?
Vicente_cgn
ZeXx86 wrote:Well, done - it should be possible to fix the problem remotely. It look like for some reason there is corrupted internal memory, but it can be fixed quite easily.
Not yet - I was waiting for your answer. :)
Please check my private message.
Vicente_cgn
I can report everything is fixed and working! :)
I got a special software that replaced the original "Spirit Settings". I had to downgrade to 2.4.3 to make this software work with my unit.
After starting the software while my unit was awake (hold nick all the time) it reported the unit was repaired - and that it was.
I reinstalled the version 2.5.0 on my unit, reconnected everything and now I can look forward to my first flight with a spirit pro. :)
Greetings,
Thomas
