Gobl. Fireball swashplate wrong direction in default setting
Hello Tomas,
I have an question - I think the direction of the swashplate (inverse 120 °) in the setup wizard is not right. The correct direction has to be 120° because look at the attched files -
Am I right ?
Best wishes
Matthias
Attach: The attached files are hardcopys out of spirit setup wizzard an sab fireball manual
you are right that for this helicopter CCPM 120 is the right setting.
If you will re-download the Spirit Settings it will be all fine :)
Regarding Throttle indicator it seems that your throttle value is way too low when Throttle Hold is engaged. It should be closer to 0%. Then it will be fine.
Hello Tomas !
Thanks for your great support :D
I wish you a merry chrismas and a good time !
Best regards
Matthias
