android app crashes SOLVED
Bladecrasher
I have 2.6.1 installed and the current (Dec2018 approx) phone app. It has been working fine, but I recently removed my Chan 7 from the bank's selection, and was going to use 7 for a special feature. When I go to the special feature area, I see my Chan 8 setup to active rescue, but nearly immediately the app crashes and loses the BT connection.
I checked the android app store and it shows being current.
Thoughts?
scvflyer
Same issue today , coming from general setting into special function (channel) - app abend.
thanks siggi
Thank you for the message.
Could you please send us your settings file? So then we can reproduce the issue.
scvflyer
Hello serviceteam,
are you talking about setting file for the modell? Or did you mean android version and information like that ? files attached with information needed
br siggi
scvflyer
tablet information
I am talking about settings file from the Spirit unit - 4ds file that you can download from the Android app or ideally Spirit Settings.
Then you can attach it here in the message.
scvflyer
unit settings.
But keep in mind it has been modified after app crash due PC spirit software. (If it's good to know)
br siggi
Goblin380-20190325-0.4ds
just bank 0
(255 Bytes) Downloaded 47 times
Goblin380-20190325.4ds
all banks
(255 Bytes) Downloaded 52 times
Thank you for all the details!
Please download this APK:
http://spirit-system.com/dl/settings/se ... -2.6.1.apk
It will be available on Play later today.
This should fix all the issues.
