Tail kick at Take off(Solved)
Pino74
Yes i am sure, that is disabled in the spirit
but the soft start in my esc does not work in any way, both with governor enabled and disabled, in esc and with governor enabled or disabled in spirit. always starts in the same way the motor, slowly then suddenly accelerates
the governor has only one flag to enable it from the Governor / throttle setting tab?see attachment and see again if u can my setting of th esc
Pino74
Option1 Fixed Wing
Option2 Helicopter External Governor
Option3 Helicopter (Elf Governor)
Option4 Helicopter(Store Governor)
I tried the first 3 options remaining the governor in the spiritalways disabled , and only the first fixed wing the motor starts immediately, the other 2 option , the slow start , but fot little seconds...then after 3 sec it accelerates a lot like in the video I showed you but I set a spool up value of 20 sec in the esc settings.
I then tried to exclude the esc governor, using option 2 in the esc which means using external governor, and I only enabled governor of the spirit one with spool up very slow, and 30 us, but it's the same thing always starts as in the video i have show you...
the situation improves only if I start with a normal curve in radio that starts from 00% throttle, I use a flat curve that starts from 70% 70 70 70 70
they told me that the softstart must work even if I start with a 70% flat curve!!!!I don't know what to think. I'm confused
I also tried to recalibrate the Throttle/ esc, from my radio , but it's the same thing. I was careful that my throttle could reach 0% and 100% before the calibration
Pino74
ZeXx86 wrote:Soft start is affecting only few first seconds of the spoolup. At the video softstart is working very well so there is nothing you can improve with Soft start.
You have to set slower Spoolup rate. Then it should be good.
So maybe I badly mean softstart ? So what does 20 sec mean as a value in my set app of esc?"start up time"see attachment
Pino74
the problem is that the Esc HW 60 amp manual is wrong, there are conflicting entries. look at the attachments.
now on helifreak they told me to use fixed wing, in esc to solve the sofstart problem, and manage it from the spirit
Pino74
I think I have solved it!
I had to use the fixed wing mode in the esc, and use the spirit governor which works very well.
I have only one problem
the rpms are right only in the tab of the spirit, but on the telemetry they are minor I find 2,000 rpm less on the telemetry.
The sensing divider and gear ratio they are well set 12.70 and 3. (140 my main gear/11t my pinion and my Motor it 6 pole/2=3)
I have only one doubt, maybe because I don't have the pinion motor attached to the main gear , I'm doing tests at the bench....???
Pino74
Hi I solved by enabling in my esc Hw,the fixed wing mode, and then the governor in spirit.
Now the heli flies fantastic
and thanks to the spool up very slow,in The Governor of Spirit Pro I no longer have the kick in the tail at take off.
urgno
Pino74 wrote:the problem is that the Esc HW 60 amp manual is wrong, there are conflicting entries. look at the attachments.
why wrong ?
is clearly written that startup-time is only valid in ELF or Store Governor mode
you was using Heli Linear Throttle
Pino74
in the same manual there is this line which is discordant with Start up time,
if the "start up time" works only in elf and store mode, they were wrong to write in the same manul of HW 60 amp,that in external helicopter linear, it(Start up time) has the same effect
Thank you for the message! I am glad it is working well now.
Kluftinger
Pino74 wrote:Hi I solved by enabling in my esc Hw,the fixed wing mode, and then the governor in spirit.
Hi Pino,
The current V4 versions of Hobbywing ESC's have to be at "External Governor"
The older V3 versions work only with the Spirit governor, if they are at "Fixed Wing"
Enjoy your OXY3!
