Stock trex 470L failed BEC test?
HateTheDrake
So I had a weird crash recently where it became unresponsive. Others point to the stock 50a esc as being too weak.
Just to confirm: the esc needs to survive the BEC stress test which tries to simulate peak load, correct?
Mine, using the stock DS450M servos, logs low voltage and rx loss each time. I bumped esc voltage output to 8.5 and it now reboots towards the end of the test.
HateTheDrake
Also note: this is on a standard spirit with a single dsmx sat. The crash was on firmware 2.6.3 or 2.6.4. All the BEC tests were on 2.7.1.
I am afraid you will have to add external capacitor to help the BEC or to lower the voltage. With higher voltage current is increasing actually causing bigger voltage drops.
It might work better with 6V but I recommend to add electrolytic capacitor of 2200 - 4700uF.
HateTheDrake
Thank you. I do plan to lower voltage back to the default of 6. I’m not familiar with adding a capacitor, will need to research.
Everyone keeps saying to get a new esc. (HW or castle)
urgno
you can get something like this one
the higher the capacity the better
HateTheDrake
Thanks guys!
dub
Hi I have these capacitors and I am fully satisfied
Logo 700,T-Rex 500X Dominator, Spirit PRO, GeoLink, Jeti DC-24
urgno
R2 buffer is the Ferrari of the capacitors ;)
HateTheDrake
I put one of these on the BEC port and it passed many tests without errors or rx drop. ...even on 8v. I’m not sure what this is rated at, maybe 2474uF.
Thanks! [emoji106]
https://www.hobbyrecreationproducts.com ... -capacitor
Genesis
urgno wrote:R2 buffer is the Ferrari of the capacitors ;)
Yes they sure are, too bad no one sells them anymore, at least not that I could find.
Blade 230 S / 230 S NF / 450X / 500X / 550X ~ Trex 470LM ~ OXY 3-285 / OXY 4-325 / OXY 4 MAX ~ Spektrum DX9 BE / DX6 Gen 2 ~ Spirit FBL
_______________________________________________
Team OXY Helicopter - Lynx Heli Innovations Field Rep
