Spirit Pro/4 Rotor Head Blades Phasing
Syngorextor
:D Hello everyone (Spiritflyers)..! Hope someone can help me out with this (eventually) an old and boring configuration : going to transform my T-Rex 700 into scale heli, with 4 (scale) blades rotor head off-course with the mighty Spirit Pro. The question is : how I'm going to to setup the phasing with the Spirit pro and any ther recommendation regarding the cycle/pitch and rpm..? Thank you very-very much and much awaiting any help.
Happy Spirit Flayer..
:mrgreen: :mrgreen:
phasing is dependent on the rotor head you have.
Modern rotor heads do not require any adjustments usually.
But to make sure everything is OK, you can put rotor head blades parallel with the boom (2 of them).
Then move with elevator stick - parallel blades with the boom should not move at all.
If this is not the case, try to change phasing angle in the Expert settings until this will be true.
Then you should be ready to fly. No other special adjustments are needed.
Cyclic Feed Forward parameter can be reduced to 3-4 so the movements will be not that sharp.
Syngorextor
:D Great and going to try out asap. Thanks for another express respond as always and hope back to you sometime after test flying.
Thank you... :D
