Happy Spirit Flayer..
Spirit Pro/4 Rotor Head Blades Phasing
Syngorextor
phasing is dependent on the rotor head you have.
Modern rotor heads do not require any adjustments usually.
But to make sure everything is OK, you can put rotor head blades parallel with the boom (2 of them).
Then move with elevator stick - parallel blades with the boom should not move at all.
If this is not the case, try to change phasing angle in the Expert settings until this will be true.
Then you should be ready to fly. No other special adjustments are needed.
Cyclic Feed Forward parameter can be reduced to 3-4 so the movements will be not that sharp.
Syngorextor
Thank you...
