Spirit gov or Kontronik gov?
eric38
Question, now i'm using the governor of my Kontronik Kosmik, can i use the Spirit governor with it?
I link the Tellme Jeti for the telemetry on the Spirit RS.
but i don't know where i find the rpm to plug on the Spirit RS...
Does somebody use his spirit with Kosmik for Governor?
And what is better? Kontronik gov or spirit gov?
Eric
buttles
Hi Eric, do you have this cable? https://store.spirit-system.com/en/acce ... cable.html
If I read correctly you do. Use Sat 1 Port. Just leave the Spirit Governor disabled but Enable telemetry in Advanced page--Telemetry. Use Kontronik TelMe.
You will need to use Prog Unit to make sure the Telemetry parameters are correct in the ESC.
I have used the Kontronik ESC Govs in all my (3) equipped Helis and they are good.
eric38
No i'm using the telme Jeti from the Kosmik and plug on E1 (or 2?), the telemetry works well, no problem.
But i don't know how to to use the rpm signal on EI/2 for the Spirit GOV...
Eric
buttles
If you have telemetry working Ok then I would just use the Gov in the ESC. Which I do, It's good.
eric38
Yes me too, but i would like to know just for my information.
Eric
