Hallo
I tried the Anti Gravity (spirit-fw-3.1.31) in my TRex 150 with µSpirit, it flies like the VBar videos on you tube.
and he jumps up when you switch banks.
"Anti-Gravity Mode" for Spirit?
official hacker distributor USA
www.hackermotors.us
www.hackermotors.us
Hello fassla
RPM = I have no idea, never measured it, is 100% throttle. it is a TRex 150.
AG = B0 0% B1 30% B2 50%
www.hackermotors.us
www.hackermotors.us
Hello
I turned it off again.
This feature doesn't make sense to me.
But the way it looks, it works just right.
www.hackermotors.us
www.hackermotors.us
This is maybe the testing what testers do.
https://youtu.be/AfZ_VPVAhXI
For higher RPM, you don't have to put pitch. that's funny. that may originate the name.
I think the descending speed is nearly same either AG value is high, 50% == 16 deg or low, 0% ==12~12 deg. And also the transition when hit AG key is smooth somehow.
plus, original request was further more to the implementation of the compensation for the external wind gust for small size helis through the collective stabilization.
Skilled pilots may not like this but this can help in limited physical conditions.
Tested today on an Oxy 4 Max and it is indeed a neat feature.
I tested continueing half-piroflips and it has been very noticable.
with 30% it felt too much and also made it nearly impossible to do tight loopings f.e., always nearing the top it "died".
Many thanks for all of that agile development! Really appreciate it!
eg183100 wrote:I tried it today. put it on a bank and tried 25%-50% but I don't see anything happening or feeling different.
What did you exactly configured.
Default setup I had plus anti-gravity - with 50% you should feel a tremendous "uplift" will flying maneuvers. Feels lighter and the heli does not feel the gravity that much.
