Question about additional SRXL2 Satellites...
Hello together,
I have an question about the possibility to have additional srxl2-satelllites at the satellite ports of the FBL, like described in the new firmware 3.20, look at the screenshot - Can I buy an adapter cable in the shop ? Please can you describe how that should be possible.
Thanks a lot in advance !
Best Regards
Matthias
Hello Tomáš,
Have I something misunderstood ? Can I attach the normal DSMX-Satellites at the Sat-ports or can I really attach an additional SRXL2-satellite at the sat ports but how ?
I see in the Shop no adeqate cable to attach for example from sat port 1 or 2 to an SRXL2-satellite -
Please can you give me for clarifcation an answer, maybe I understand this here not right ? :oops:
Thanks !
BR Matthias
you can connect SRXL2 satellites at the SAT ports. We will make available the cable, hopefully on monday.
So for example you can connect up to 3x SPM4651T satellites.
Hello Tomáš,
thanks a lot for your fast response and great support !
BR Matthias
Hello Tomáš,
sorry I know that you are very busy but I want to ask when the new SRXL2-cable (for more than one satellite) will be available in the shop ?
By the way is it then possible to mix different satellites as SPM4651T and SPM9747 (both are Spektrum)
Thanks a lot for your answer !
BR Matthias
