Geolink Autohomepoint
erti74
Hallo ,
muss der Autohomepoint nach Bestätigung ( Taumelscheibe Bewegung) ausgeschaltet werden oder kann der Schalter so bleiben in seiner Stellung und ich kann Losfliegen ?
Lg
Hi ,
does the Autohomepoint have to be switched off after confirmation (swash plate movement) or can the switch stay in its position and I can fly off?
Lg
It is better to switch it off.
Or even better you can use 4th mode of the Return to Home feature.
Then no programming is needed at all. Mode will return to lift off position in this case.
erti74
Oh Thanks
4Th? how do i set this? i haven't seen
erti74
Ok ... i found it
