My position hold doesn't seem to work.
XY position holds steady, but the heli moves up down, getting more violent and bigger jumps as time passes.
My vertical gain is set to 10%.
Is it safe to just keep reducing this value to zero?
Geolink position + altitude hold
it should hold only XY, not altitude.
For this purpose there is Altitude Hold.
Dr.Fleming
On what place is your GeoLink mounted !!
jjuk wrote:Attached is my settings file for my Align 500x that oscillates when pos+alt hold is engaged.
Dr.Fleming
That's strange , on the boom is the best place ! Checking if there is magnetic fields near-by.
Or Tail Blade producing too much vibration! I installed a brand new SAB Tail, and these
ones have a very bad quality.
By the way, have you touch the windows " Servo Travel correction" ??
jjuk wrote:Tail boom.
I would expect the altitude to be regulated by the onboard baro inside the geolink rather than gps.
If the baro is accurate, vertical position hold should be very steady, like on a drone.
I could try swapping the geolink with my other module I guess.
Dr.Fleming
First check the " Servo Travel correction window" if you touch the values for triming the swashplate,
there is the problem.
Second, if you clued the connector in full on the spirit, and therefore the Baro not get air inside,
than you are in trouble.
jjuk wrote:I would expect the altitude to be regulated by the onboard baro inside the geolink rather than gps.
