Problem with flight log with Spirit GT
Herve
I must have missed something with my new Spirit GT because it doesn't log any information about flight.
I have done some tests without really flying, but with motor on and without blades fly in my hand (!) for 20-30s just to see something.
Please, tell me what I forgot or I didn't understand !...
Thank you for your help and have a very good day.
Hervé
Pb flight log-1.4ds
(255 Bytes) Downloaded 83 times
you need to fly model in the air. Then it will work.
Herve
Argh ! I thought that I was able to see the flight logs just moving the heli in the air with the motor on (without blades) ...
because in the manual you said :
3 Engaging Logging
Logging is automatically started without any intervention. It is completely seamless so pilot do not have to care about the feature. As soon as unit will detect a motion or vibration from the rotating parts, it is started. Without started motor logging will not trigger.
I was in a hurry to see that because I won't be able to fly before few days with my old czech heli :D
Thank you for your quick response.
Best regards.
Hervé
Herve
First of all, the measurements are well logged, thank you.
I'm back with something bizarre !
In the end of each flight I have a peak of all mesures and the scale is wrong. I think it is when I switch off the ESC (Jeti Spin 44).
If you have a suggestion/idea ?!... I thank you very much.
I didn't try to unplug the LiPo instead of switching off the ESC ...
With regards
Hervé
