Geolink v2 crash internally
AlexAusTelfs
Hi Tomas,
is there a way to manually re write Bios of Geolink v2?
Option is greyed out.
Thx
Alex
yes, it is possible. But it is not needed unless you try to flash some wrong firmware to it.
What does it mean "crash internally"?
AlexAusTelfs
It suddenly stop working after 10 to 40s in flight and led went out.
Alex
reflashing firmware with the same version will not help unfortunately.
But we found the issue and I believe we have also solution.
Anybody that want to test new GeoLink firmware please let me know.
gerry
Hallo Tomas.
Ich würde die Geolink Sofware gerne testen.
LG Gernot
Greetings Gernot
I sent you a private message with instructions.
Pking
Hi Thomas,
Is it only affecting Geolink V2 ?
Thanks !
Envoyé de mon iPhone en utilisant Tapatalk
sacha
Hello Tomas
I'm also using the Geolink V2. I used one on a TDR without any problem. It recoreded speed until the end of the flight.
See the graph.
If you need another tester, please let me know.
Sacha
