today I have logged a flight only in SpiritSettingsLog without transmission to transmitter since that doesn't work (FrSky FPort1) till now -
The values are not valid in my opinion since powers of ten are definitely not correct here -
My configuration of the Hobbywing V4 120A can you see in the attached picture -
I have also attached the log file of this flight - if the vibration values were correct, my heli would not fly so well - furthermore the ESC temperature is not correct at all, at the end of the flight 4°C, with an outside temperature of more than 25 °C - The consumed capacity is ca. 42500 mAH, I have a 5000mAh battery - I don't think it can be due to my configuration, see picture attached, but I'm still happy to be instructed if I configured something wrong -
Unfortunately, the telemetry is of no use at all -
I hope someone can help me -
Thanks in advance !
greetings
Matthias
Telemetry values in SpiritSettings_LOG implausible..
- Attachments
- 210822_Flug_2_SpiritSettingsLg.zip
- SpiritSettingsLogfile from 210822
- (2.59 KiB) Downloaded 68 times
Hi, same problem at me, also with Hobbywing Platinum 120A V4. Tomas told me to reduce the log data, that could help.
I´am testing it now, the best experience to me now is set max. 4 parameters at 10Hz. Don´t forgrtt to delete old log´s.
Your vibration log looks very bad, but even not real.
with best regards
notround
notround
I was flying fast aerobatics, also hard stops with the heli and at the end of the flight I testet rescue, that works absolutely perfect - no abnormal behavior but rescue absolutely vertical, that's why the vibrations can't be...
I'll be happy to test your suggestion, maybe today, let's see -
greetings
Matthias
greetings
Matthias
very likely your ESC is flashed with wrong firmware for VBar. Please flash firmware that is not ending with "VBar" label.
Then it will work.
Then it will work.
Hi Tomas,
I had the correct firmware for the Hobbywing 120A V4 selected (non Vbar) !
Today I have deactivated the logging in the SpiritSettingsLog the values are not right -
The values shown in the transmitter are in my opinion valid - the values of RPM (2400 U/min / 2100 U/min/ 1850 U/Min ) and Battery voltage (25,2 V to 22,5 V) and temperature of the ESC are also true (max 37°C) - the vibrations are max. 20% I think thats also ok !
The telemetry data could only be transmitted to the TX16S till the right firmware was flashed on the R161 (LBT V2.10 D16) which I successfully flashed today -
So I think the SpiritSettingsLogging tool must be be revised in my opinion because the values are not true -
Matthias
Matthias
In this case please clear all logs from the Spirit GT unit, then try to enable just one telemetry variable for logging and verify if it is OK.
I believe this will help.
You can select any rate for logging. Trying only one variable will be great.
Hi Tomas,
Unfortunately not good news - I completed a test flight this evening, before that I deleted all log files - I only recorded the speed (RPM), i.e. only one parameter, with 10Hz, you can see the result in the attached log - Very large fluctuations, although I principle, after a certain time I switched to the second and then the third in all three speed levels and then flying around- I had already indicated the speed values yesterday, which I had read from my remote control, the values also seem to be realistic when I do a math with the values as the motor kV, the corresponding voltage and the gear ratio to the approximate controller opening, the speeds are quite good - I can only say here that the speed values in the Log are not comprehensible - I will definitely switch off the logging, since that is of no use to me - maybe you will find a way how that can be corrected that would be great - from what comes that value showing in my transmitter (here speed) is correct and not in the log, I don't understand -
Many greetings
Matthias
Many greetings
Matthias
- Attachments
- Testflug_Nur_RPM_SpiritSettingsLog_240822.zip
- (4.59 KiB) Downloaded 61 times
