At first: Flying the units is perfect.
My setup: Spirit GT + Geolink V2 on a RAW580
Spirit GT + Geolink V2 on a TREX 600E PRO
The vibrations are between 8 and 20
BEC test succesfull
But when i like to use the supported features i run in problems.
After the update is the same than before the update at my units, nothing gets better.
1.When i like to look in the Geolink log´s the first log is most possible to look.
The next flights are set with timestamp 0 and not choosable.
A fault that the geolink data are corrupted is shown in the log viewer.
2. When i take the advanced fligtviewer try to look in the realtime log there are crazy high values which "kills" the logs.
For example: speed 6000km/h, Vibration 2400
it is independant which or how much values i set and how often per second i set.
I´ve done factory reset, reprogramming. Update every unit to 3.4.2 and 1.3.1
nothing helps
But, once more, flying is perfekt
Sprit GT and Geolink V2 fault´s in log
- Attachments
- Bank0RAW.4ds
- SettingsBank0
- (255 Bytes) Downloaded 80 times
- spirit-log-2022-08-29-134206.pdf
- Here is where the Geolink quitts
- (60.67 KiB) Downloaded 93 times
with best regards
notround
notround
thank you very much for the question and sorry for the troubles.
We will check your settings and logs. It seems there are two different problems, because both logging are completely separated from each other.
Unfortunately I fear it will require adjustments in the software.
Hello Herve,
I think we have all the same problems (notround, mattes61 and you) Tomas said that there will be an update to fix the problem in some days
Look in my thread also:
https://www.spirit-system.com/phpBB3/vi ... 9&start=10
Matthias
Matthias
update and more problems.
The log´s in the Spirit GT unit are perfect, after update, now.
Problems with the geolink v2 log are still there.
When i look in the Geolink log´s there is only one log after two flights.
At the first try to download the log the connection with the geolink get lost and error thrown "data corrupt".
After reconnect power the download is possible.
Updates GT unit and Geolink v2 are done
Old log´s deletet
Testet on 3 days with two GT units and one geolink v2 swapped between the GT units.
Every day the same.
The altitude hold and autolanding is very "jumpy", tried gains between 100 - 50%
What can help?
Old log´s deletet
Every day the same.
What can help?
with best regards
notround
notround
if your model is producing too much electrostatic discharges the GeoLink itself could restart, because it is sending too high voltage there. This is indicated by Green led light after landing.
If this will happen GeoLink log might not show for the present flight immediately. But it is fixed automatically when next log is added.
You can check if after more flights the missing log will show. Although high voltage spikes are relatively dangerous for whole electronics on the model we will try to make it seemless even if logging is interrupted in next updates.
For now it is enough to do more flights and the logs are fixed automatically.
Can you share how GeoLink is mounted on your model?
You can start with the minimum value for the Vertical Correction Gain. This should help.
