spirit rs help
you can decrease Cyclic Ring value and also Rescue Collective Pitch.
Can you make sure that when you enable Servos/Subtrim (tuning) then all servos are in the center position and there is 0° between main blades?
franz88
I changed my pinion and I mounted a pinion with 2 extra teeth.
Now with all governor parameters standard the governor IS PERFECT keeps the rpm in a fantastic mode.
Also I'm updating the spirit and in this version now you fixed Diagnostic-rescue, now the written goes out exactly.
Geolink altitude limit i keep the standard parameter 0.
I want what a minimum altitude I decide it on every flight but this parameter is fantastic, it really needed.
In known versions it is written works with on2 but on the manual or in the help popup it is not written on2.
Compliments
I just have one problem.
When I give negative pass and then I try to take a positive pitch.
In this moment what parameter can i move?
In this moment seems to lose stability.
pitch pump booster?
Or i try to move rudder delay?Now is 5
trex500.4ds
(255 Bytes) Downloaded 97 times
franz88
i tried the return home and he is much more nervous when activated.
Altitude limit and rescue normal is ok.
When I deactivate return to home and stick throttle is in different position my model takes a shocking backlash.
When I deactivate the return to home the pitch of the stick can't it be more gradual?
franz88
zex you contact me in private and write one email and i send you one video with wetransfer (for big files).
I have one video with altitute limit, rescue normal, and after return to home .
If i use youtube others see it too and I want to show it only to you.
In video you can see .
If I set slower after rescue is too slow.
I believe that the return home it must be settled to his activation and his deactivation
thank you for the videos. They are very helpful, I will check immediately email from you.
Unfortunately I have no email from you yet.
franz88
ok ZeXx86 now I fixed my head.
Now i have 0 degrees at center stick in all 4 blade positions.
12 degrees at maximum sticks in all 4 blade positions.
-12 degrees at minimum sticks in all 4 blade positions.
i send you one pm for return to home
franz88
hi
i create this video for you to see
https://youtu.be/kWrMo3BSo-w
can you explain me because I'm active limit altitude geolink a few meters off the ground (2 or 3 meters)
but even if it activates in the 5 meters it's ok for me.
But if I do some 3d maneuvers after that it activates much higher.
It activates at 15 or 20 meters.
why?not is normal
I am attaching spirit settings and radio log jeti ds 12
in log jeti there are RPM - VIBRATION - ALTITUDE
trex500.4ds
(255 Bytes) Downloaded 111 times
17-43-54.log
(249.92 KiB) Downloaded 97 times
franz88
I edited the video for you.
after you've seen it I have to delete it
after checking the settings and log I can see two important problems.
First is - your settings has Collective Pitch reverse - this is required only for models that have some kind of mixing which mean that when swashplate goes up then resulting collective pitch is negative. When it is down, then it is positive.
In all other models it must be not enabled otherwise functions such as Rescue, Stabilisation, all GeoLink functions will fail sooner or later.
Because your model require this settings it also mean that other base settings must be wrong. Unfortunately this mean that even servo wiring could be wrong, including servo reversing.
This is thing that must be resolved as soon as possible, because all FBL functions will work very poorly and incorrectly, even if it does seem it fly well.
Next important thing is to resolve extremely high vibrations. Your model is reaching nearly 120% all the time which is order higher than model should be normally.
This could have impact on Rescue/Stabilisation and all GeoLink functions as well. With other FBL units it is very probable it would crash immediately after lift off, because it will confuse the sensor. So please make sure to fix it to be at least at level around 50%. Your model can easily fly with 15% if all will be fine.
This is important also for good safety, because even secured bolts can unscrew.
