FrSky Integration with Ethos, S.Port & F.Port
Loetefix
With FBUS connection the channel limits matches perfectly to the Frsky Channel limits. But the channel order from the first 3 channels is still wrong. can we correct this please for fbus?
This will remain unchanged so that Spirit layout will be at default while FrSky layout too.
In this way no change is needed from default layouts on both sides.
Loetefix
Ok.
It is verry irritating when the radio shows for example pitch is send on channel 1 and the spirit-software shows it as channel 3.
This is because each manufacturer has own channel numbering.
Our aim is to make layout uniform with any receiver, radio, protocol.
These are only numbers that you do not have to change in any way. These numbers can be replaced with letters or anything else. But still result will be same.
Storchy
I want to have a look on the log file.
How is this possible?
I have the spirit.luac 3.4.4 on Frsky XE Ethos 1.4.7.
I cannot find the viewer.
If i connect the Wifi Modul and Android 3.5.2 i can open the viewer under diagnostic.
Is this the only possible way?
yufasa
As Ethos do not currently have a log viewer you will need to download the log file to a device where you can view it.
This can be done with the WiFi or usb connector.
Hopefully we will get a log viewer in the new Wave radio :)
Dudemeister
yufasa wrote: Hopefully we will get a log viewer in the new Wave radio :)
Speaking of this, @ZeXx86 Can we have some information regarding the new radio you're planning?
So far all I've seen is other folks mentioning it in various forum, but I can't find ANYTHING else regarding this future product.
Come on, Tomas, give us a little info!! :D
Storchy
I am looking for a lua script like logviewer.lua for OpenTX.
I hope that Tomas finds time to program this for ETHOS
I found something in an other forum - you can look your ethos logs with companion (Opentx or edgetx) they seam to be compatible with it -
https://www.rcgroups.com/forums/showthr ... OS/page797
Storchy
I want to look at the Spirit Log under ETHOS,
not on the Ethos Log under Ethos.
