Can Position and Altitude Hold be engaged on the ground?
MichaelT1960
Anyone in support know the answer?
Why doesn't my helicopter leave the ground.
Lifts off fine in normal mode with these settings off!
Michael
Rdlx3m
You can NOT have it active while on ground! Only use it while youre in the air
MichaelT1960
Someone finally answered my question!!!
Thank you!!!
Michael
Rdlx3m
Well.. it says it self.. if gps has locked.. and yoi activate GPS hold on the ground.. what you think is gonna happend heheh..
It stays at the position you tell him to. And your RETURN TO HOME wilø come directly above where you took off
Simple answer - it is not recommended, especially not altitude hold. Because it will hold altitude and you will be unable to lift off...
MichaelT1960
Doesn't it matter what mode of altitude hold is selected (1 or 2)?
In the manual it says that one allows collective pitch changes and the other does not!
Michael
