Goblin raw 580 spirit gtr
franz88
ZeXx86 wrote:Hello,
when adjusting Servo Travel Correction you are changing travel of positive and negative part independently.
They are not affecting each other at all.
Maybe you set Reversed Collective Pitch in the Advanced tab. Is this correct?
This is not correct settings for Goblin Raw.
I created a new memory and after has changed.
I set +13 and after -13 and they remained fixed.
I suppose had some mixer or setting set up.
Now it's okay
Please can you tell me how on my radio jeti ds12
I can see in real time :
vibes %
s rpm
s altitude
s speed
s gpd lon
s gps lat
s gps sat
with other radios I can not see them
with jeti ds12 i could see them and record logs on the radio, is one integration only with jeti?
I dont understand from your question which radio is displaying telemetry and which one is not displaying.
Please clarify your question.
franz88
I put the second plug to have the bec backup but when i land just before disconnecting the wires, the geolink v2 flashes 1 time and in the log the message comes out geolink connection is broken and geolink logs they are not record.
why????
always at the end of the flight I am attaching the log 1
spirit-log-2023-08-26-184537.pdf
(65.95 KiB) Downloaded 200 times
and 2 log where I tried to increase the rpm
spirit-log-2023-08-26-192731.pdf
(65.46 KiB) Downloaded 177 times
but the log on the bench without flying they have no geolink error and obviously without starting the engine
spirit-log-2023-08-26-193020.pdf
(60.62 KiB) Downloaded 175 times
franz88
this error it may depend from the hobbywing esc or from the engine.
why in the other helicopter this geolink it didn't have this error.
but let's cut the bull's head off.
If the error comes out a few seconds before turning off the unit can't you ignore it and prevent the log from disappearing?
these errors interfere with geolink functions
do you have a bufferpack on the heli? to me, the errors at the end of the log appear as if the voltage from the BEC may decrease after landing, and then the GEO will be silent
this error can show up at the event of landing. Exactly at this moment strong electrostatic discharge can develop. This will disturb mainly GeoLink, because it is usually mounted right above the source of this discharge.
With some helicopters it is happening basically every flight (also without GeoLink) and you can see corrupted frames from receiver or in rare cases even receiver malfunction for 1-2 seconds. Usually it is enough to increase belt tension.
It is like hitting electronics with 1 - 10kV which is similar to a thunder lightning. In this case electronics can also be destroyed.
franz88
I have hobbywing v4 130 amp esc this esc has the bec incorporated
first in the other helicopter i was using bec robbe it cost much less but with the bec robbe I didn't have the error, i was using a separate bec and a 2s lipo to power the electronics.
While now i bought hobbywing esc with bec built in.
but it could depend also from the settings esc (timing, pwm) or from the engine.
I think more about pwm.
Along with the esc they gave a capacitor I didn't mount it because I asked around and no one uses it, let's say that in addition to cleaning the current it should store current and should serve in voltage drops.
but i have the logs of the voltage of the bec and it's perfect, jeti and spirit gtr have the ability to register the voltage of the bec and it is always constant it has no drastic dips.
let's compare our electronics.
where i have the error I ride
esc hobbywing v4 130amp (bec incorporated)
motor EGODRIFT tengu 4025hs/550kv (12s)
tail servo X40THM-H
GDW - DS498MG 3 servos
spirit gtr
sab goblin raw 580 12s
tell me your electronics (why changing electronics the error came out the geolink is the same)
PS
I started writing the post before you replied zexx86, at the first start I saw the sparks with the naked eye.at the first start of the belt.
zexx86 tail servo X40THM-H gdw how much should I put the servo delay? now is 5 but it is not in the list and my tail it's slow, before increasing the parameters I want to fix the delay
I can't find your tail servo anywhere. Probably it is called differently. Please check the name and correct it or send link of the manufacturer.
franz88
it says on the box https://www.agfrc.com/
the one with the blue rectangle
it says aol but i believe it is agfrc
you can set Rudder Delay to 0-2.
Pirouette Consistency to 175 - 185 should be fine.
