Rescue Duration
Hi, playing around with Rescue (Normal) today. Tried the Rescue Duration to see how it performed. Then tried to un-tick it but it stays checked. Hopefully something simple to fix but am stumped!! A basic search didn't come up with anything. Thanks
one thing will work, I have it no tried but it should -
Disable all settings (function) in all three banks so that you have no stabi - save this settings in your FBL - then power up new the FBL, then there must be stabifunction disabled in all banks -
Then set all banks again as you want and safe it in your FBL - start the FBL new (new power up) an look if all setting are like you wanted -
If that doesn't work then there must be something wrong and then Tomas has to look what kind of problem that can be -
Hint: I personally dislike autosave and save all manually but that's only my humble opinion -
