Rescue Duration
buttles
Hi, playing around with Rescue (Normal) today. Tried the Rescue Duration to see how it performed. Then tried to un-tick it but it stays checked. Hopefully something simple to fix but am stumped!! A basic search didn't come up with anything. Thanks
have you really saved the un-ticked configuration or only changed but not safed ? Sometimes you just forget that in a hurry -
Another thing have you banks activatet then un-tick them in all banks -
buttles
The autosave function is active but I also backed that up with a manual save. Alas, the same.
Been through all 3 banks and it also doesn't clear the tick.
Tomas will have to confirm how that particular function is handled I think
one thing will work, I have it no tried but it should -
Disable all settings (function) in all three banks so that you have no stabi - save this settings in your FBL - then power up new the FBL, then there must be stabifunction disabled in all banks -
Then set all banks again as you want and safe it in your FBL - start the FBL new (new power up) an look if all setting are like you wanted -
If that doesn't work then there must be something wrong and then Tomas has to look what kind of problem that can be -
Hint: I personally dislike autosave and save all manually but that's only my humble opinion -
buttles
Thanks for your suggestions. It's not my Heli so can't access it at the moment. We did disable the Stabi functions, save then re-enable Stab normal. This is using the latest software in an old Red unit.
