[SOLVED] Rp3-h elrs receiver. No telemetry values.
Mona
Great, thank you. Looking forward to it.
ELRS integration is ready. Anyone interested can get early access.
tmura
Thank you for your assistance.
Where are the earlier versions?
From pc software I can see 3.7.2-r2
Please write me private message with serial number of your unit. We will assign new firmware there.
We assigned firmware to these that sent me a message.
Compatibility with all ELRS receivers should be perfect now while all recent Spirit units have full Spirit integration now. Photos in the attachment below.
tmura
RP3-H telemetry is stable on the bench with 3.7.4.
My setup are below:
- spirit GT
- RP3-H elrs 3.4.3 (250hz/telem ration 1:8)
- RM Boxer / BetaFPV nano TX v2
- HW Platinum 80A V5 (w/DIY telem uni cable)
Pack voltage and current are available without interruption.
(Note: I had to swap the tx/rx pins on GT unit)
Thanks! :D
IFHELI
Still does not work for me. I will have too look at it later tonight.
IFHELI
More trouble now. The Spirit GT will not power up now wired as needed on this firmware. Go back to 3.7.3 and flip the wires it works but no telemetry or integration.
Please post photo of how it is wired. I guess there is something wrong since other that tried it with GT with same receiver have no problem.
Maybe you are using some special settings of the receiver?
IFHELI
I can load 3.7.3 back into Spirit GT and swap white and green wire back and it works fine (no telemetry / integration as expected). black,red and white wire at Rudder port... green at ail port
I load 3.7.4 into the Spirit GT, swap white and green wires. black, red and green wires at rudder port... white wire at ail port. Rx will boot up.GT does not boot up. HW 80A ESC just beeps. No blue light on GT. Servos have power but will not move. No integration or telemetry. Will not connect to software on computer using USB dongle.
Using Spirit 3.7.0 on TX.
I can unplug wire to Rx and plug back in and it will all boot up just no integration or telemetry. Shut it all off and GT will not boot up again.
