problem tail
franz88
after update version 4 he came out this problem.
I believe stop A and B is hard if i set 3 the sound decreases but it doesn't disappear (it's an opinion I could be wrong)
https://youtube.com/shorts/TQM9IB6-GhA
spirit gt raw 580 tx16s x8r s.bus X40THM-H
raw580.4ds
(255 Bytes) Downloaded 1028 times
There is nothing wrong. You can leave default value 5 and 6 for the first flights.
franz88
is normal this sound?yesterday the sound did not exist
Yes, it is normal. There is difference because of different algorithms used that are responsible for tail stopping. It is only sound. Problem is if it does not work in the air.
franz88
ok but is normal I just have to try it in flight
can you tell me the value 9 How many degrees per second is this?
Value 9 is around 250 deg/s for cyclic or 400 deg/s for tail.
