after update version 4 he came out this problem.
I believe stop A and B is hard if i set 3 the sound decreases but it doesn't disappear (it's an opinion I could be wrong)
https://youtube.com/shorts/TQM9IB6-GhA
spirit gt raw 580 tx16s x8r s.bus X40THM-H
problem tail
- Attachments
- raw580.4ds
- (255 Bytes) Downloaded 1010 times
There is nothing wrong. You can leave default value 5 and 6 for the first flights.
Yes, it is normal. There is difference because of different algorithms used that are responsible for tail stopping. It is only sound. Problem is if it does not work in the air.
Value 9 is around 250 deg/s for cyclic or 400 deg/s for tail.
