Altitude Limit was activated far above configured altitude
No.
Open the software, then in General - Channels assign Throttle to Channel 1.
Save the settings.
This should resolve your problem.
Save the settings.
Unfortunately no, I dont meant this.
I only meant to do these steps:
- Open the software
- Go to General - Channels page
- Assign Throttle to Channel 1.
- Save the settings.
Yes.
Unfortunately, setting channel 1 to throttle didn't make a difference. I flew once yesterday, and the altitude limit was triggered again.
I'm attaching the flight log.
- Attachments
- Log 20-08-2025.4dr
- (62.93 KiB) Downloaded 614 times
I updated the Spirit GT today from version 3.7.2 to version 4.0.0. I set the recommended rotation speed and rudder delay values from the update description.
I also reinstalled version 1.4.1 on the GeoLink v2, which took about 10 minutes, not 75 seconds.
After that, I flew twice without the altitude limit being triggered uncontrollably.
When the minimum altitude was exceeded, it was triggered as intended.
I don't know the reason now, but I hope it stays that way!
On Wednesday, I finally got back to flying. I made three flights, the first and second of which went smoothly.
On the third flight, the altitude limit was triggered again during a flip. I turned the function on and off several times, but each time I turned it back on, the helicopter climbed away.
Then I landed, turned off the engine, and restarted, and everything was fine again. The altitude limit could be deliberately triggered by falling below the minimum altitude, and it automatically deactivated again after gaining sufficient altitude.
This time, I couldn't find any abnormalities in the Altitude-Tab in the logs "2025-09-24_3rd Flight Part 1_17. log.4dr" and "2025-09-24_3rd Flight Part 2_18. log.4dr."
- Attachments
- 2025-09-24_3rd Flight Part 1_17. log.4dr
- (23.28 KiB) Downloaded 316 times
- 2025-09-24_2nd Flight_16. log.4dr
- (67.58 KiB) Downloaded 367 times
- 2025-09-24_1st Flight_15. log.4dr
- (66.21 KiB) Downloaded 289 times
