Spirit - Frksy Ethos app with 4.02 firmware
kgnkazanci
I've upgraded my unit to 4.02 from older than 4.0 at home, double checked everything at settings as per explained at change logs,
and then headed to the field.
When I tried to adjust rotation speed at sensor tab on Ethos Spirit app on my transmitter, values were shown different such as;
280 deg/s was shown as 2.8
300 deg/s was shown as 3.0
When you change it, the minimum value it's allowed to enter was 4.0 which corresponds 400 deg/s and too aggressive for minimum point.
Is there any way to update parameter min max values on Ethos Spirit App?
Lua script must be updated to work correctly.
Hello Tomas,
does this mean that we get an updated lua script ?
Best regards
kgnkazanci
Hi,,
I didn't see an updated lua script at the time when I asked,
But later I saw there is one,
The file name is spirit-ethos-4.0.0,
This works with the newest firmware,
Bests
thanks a lot for your answer, if 4.0.0 works then its all ok ! :D
I thought the 4.0.0 doesn't work anymore -
Best regards
