I've upgraded my unit to 4.02 from older than 4.0 at home, double checked everything at settings as per explained at change logs,
and then headed to the field.
When I tried to adjust rotation speed at sensor tab on Ethos Spirit app on my transmitter, values were shown different such as;
280 deg/s was shown as 2.8
300 deg/s was shown as 3.0
When you change it, the minimum value it's allowed to enter was 4.0 which corresponds 400 deg/s and too aggressive for minimum point.
Is there any way to update parameter min max values on Ethos Spirit App?
Spirit - Frksy Ethos app with 4.02 firmware
Lua script must be updated to work correctly.
kgnkazanci
Hi,,
I didn't see an updated lua script at the time when I asked,
But later I saw there is one,
The file name is spirit-ethos-4.0.0,
This works with the newest firmware,
Bests
Bests
