model preset up to date 4.0.2 r2 ?
pusher
have the model presets been tested with the latest version 4.0.2 r2, and are they considered reliable for use?
this is also what I want to know of the Specter 700V2 preset -
Thanks a lot for the answer ! :)
Best regards
Hello Tomas,
it would be nice and helpful if you can answer these questions -
Has something to be changed before flight in the presets ?
Tanks a lot for the answer !
BR
Matthias
we are not aware about any reason why there should be any issue with the presets.
You always have to set servo related parameters precisely and at least tail gain. If model is mechanically fine, it will fly well right during maiden flight.
Hello Tomas,
thanks for your answer !
That means no special settings as stated in the udates before rudder delay at first setted to "0" ?
The delay can be setted as described fast servo-->analogservo...?
BR
Matthias
All the presets of the Setup Wizard were updated accordingly with Rudder Delay some time ago.
On the other hand if you update from previous versions, all recommendations that are in the ChangeLogs should be done.
Hello Tomas !
Thanks a lot for your answer and clarifying :)
BR
Matthias
