Tx16s zeroed but showing -5 pitch in servo page.
Mistralis
Hi when I come to set up the servos in Spirit software I get - 5 on the pitch indicator with the tx showing 0 output and -10 at bottom stick with with the tx showing -100. Is it the tx or what?
show an screenshot at spirit settings...
At first you have to set your servos individually at the middle impuse 1500/1520 then put the servohorns on that it is perpendicular to the servo case - that you should do on all sevos at first. Then mount these servos in the helicopter -after that you have to take a swash leveler (for swashplate) and adjust that the swashplate is leveled out. At this position the pitch must be adjusted to 0° - this is your Initial setup for the rest of the settings in the Spirit Settings Software -
Best regards
