[Solved] Rotor disc occasionally shakes
bovi7
I flew Jeti/BeastX for about 10 years and switched my 5 Trons to Wave/SpiritW1 this spring. I mainly fly aerobatics and smooth 3D. My Tron 5.8 is running at 1650 RPM.
Overall, I'm very happy with how the Spirit flies now. It feels exactly the way I want in almost every aspect. However, there's one issue I'd like to improve.
During piro tic-tocs, the main rotor disc occasionally shakes when I make aggressive pitch inputs. It doesn't happen all the time, but often enough that I'd like to understand what's causing it.
I'd really appreciate any ideas or suggestions. I've attached my current Spirit settings for reference.
Thanks in advance!
MySpiritSettingsTron5.8_20260710(1).pdf
(63 KiB) Downloaded 378 times
cyclic pitch should not be higher than collective pitch - max. equal !
Can you reduce your headgain a little bit ? 3-5 lower than now adjusted ?
I think you are not in the 3D-Master-Mode - but thats absolutelly ok !
Look at this link maybe this helps:
https://manual.spirit-system.com/index. ... LIC_TUNING
BR
bovi7
Thank you very much, i going to try today.
bovi7
Nazar
I am not an expert but to me it sounds like under heavy load one blade has more lag than the other which creates unbalance in the rotor.
Make sure both blades are tightened down equal.
bovi7
Thanks for the hint, gonna try it!
bovi7
I made cyclic pitch equal to collective and reduced swashplate dampening to 20. Now the occational shakes went away.
