I flew Jeti/BeastX for about 10 years and switched my 5 Trons to Wave/SpiritW1 this spring. I mainly fly aerobatics and smooth 3D. My Tron 5.8 is running at 1650 RPM.
Overall, I'm very happy with how the Spirit flies now. It feels exactly the way I want in almost every aspect. However, there's one issue I'd like to improve.
During piro tic-tocs, the main rotor disc occasionally shakes when I make aggressive pitch inputs. It doesn't happen all the time, but often enough that I'd like to understand what's causing it.
I'd really appreciate any ideas or suggestions. I've attached my current Spirit settings for reference.
Thanks in advance!
[Solved] Rotor disc occasionally shakes
- Attachments
- MySpiritSettingsTron5.8_20260710(1).pdf
- (63 KiB) Downloaded 222 times
cyclic pitch should not be higher than collective pitch - max. equal !
Can you reduce your headgain a little bit ? 3-5 lower than now adjusted ?
I think you are not in the 3D-Master-Mode - but thats absolutelly ok !
Look at this link maybe this helps:
https://manual.spirit-system.com/index. ... LIC_TUNING
BR
BR
