New unit semi-quick check
gdenton61
I just received my first Spirit 3 unit, but it's gonna be some time before I do the full setting up.
I am wondering if there is a semi-quick way to check if the unit should be good to go?
Thanks for any input.
senaka
Connect the unit to the Spirit settings software., When the unit is booting up it does a systems check and reports back, on the [connections] section in the software you should see status: OK. You may have to connect your RX for this check.
