I just received my first Spirit 3 unit, but it's gonna be some time before I do the full setting up.
I am wondering if there is a semi-quick way to check if the unit should be good to go?
Thanks for any input.
New unit semi-quick check
Connect the unit to the Spirit settings software., When the unit is booting up it does a systems check and reports back, on the [connections] section in the software you should see status: OK. You may have to connect your RX for this check.
