I Need your help Jeti + Spirit 3 please
Christian
What I see from your pictures, this is NOT a default setting in the Spirit.
Not even throttle is assigned :o
Please
1. Reset the Spirit (Werkszustand)
2. If needed, update for latest firmware 4.0.4 -> for Spirit itself and also for the Jeti .bin file.
3. Set "Jeti ExBus" in Spirit receiver tab
4. find the correct channel assigment in the "channels" tab.
Christian (Germany)
Flyfrank
Hi Christian,
throttel is assigned on a switch and i do have cut off as well, this works in every heli i use.
But I found the problem, hopefully, I did not reset to default!
I am trying right now with a complete new setup.
I´ll let you know.
Frank
Christian
You can assign throttle to a switch or whatever you like. This is not a Spirit topic. This happens inside your Jeti.
And of course, you have to tell your FBL which channel of your receiver is allocated to which control input. This is the same for all FBL on the market, as long as your are working with individual receivers.
For Spirit, it is so easy. Just open Channel Tab and select the correct channels for every input. If something is swapped - swap it back ;)
But, the default setting in Spirit and Jeti should perfectly match for the first 6 channels.
Christian (Germany)
Flyfrank
Oh boy,
The problem is or was definitely due to the factory reset!
Good to know…
The only thing is that the integration with Jeti still shows incorrect values under “Diagnostics.” I have the latest firmware and have loaded the DA file; I’ve double-checked everything.
Okay, time for some fine-tuning and the first test flight.
Many thanks to everyone.
Frank
Christian
That sounds good :)
Yes, the Jeti integration has still some small things to improve.
Christian (Germany)
if you will assign Throttle to Channel 1 and leave Gyro Gain assigned to to Channel 5 it will work.
