All Controls Suddenly Gone!
we prepared new PC software that has JETI Integration file updatinng support by one click. Unfortauntely through the years we found some users are having hard time for doing this update, thinking it was really updated (but it was'nt in reality).
Since both version 4.0.4 and 4.0.5 are used by thousands of pilots, while 4.0.4 is used for months now, I think old BIN file could be the only possible reason that can explain this behavior well.
I am not sure what logging issue you have, but most likely it is unrelated. It could be resolved by pressing Clear Logs button in the software.
Here you can download this PC software:
https://spirit-system.com/dl/settings// ... .6-win.exe
At the Update tab you will see new JETI Integration submenu where the app will automatically update the BIN file just by one click. You only have to connect your Spirit unit and JETI radio using cable.
Phil S.
Unfortunately, the current version (of integration, NOT firmware) isn’t displayed anywhere in the Jeti Integration. But I have two clear pieces of evidence that it is indeed V4.0.4r2:
1. With Spirit firmware V4.0.4, "Channel Values" are displayed correctly under "Diagnostics"; the "Diagnostics bug" has been fixed.
2. Under "Advanced" and "Expert settings", the "Swashplate - Stop Smoothing" setting is available.
As for the logging problem:
Neither of my GTR Spirits will start recording data. I’ve spent hours trying to sort out the problem with the help of the AI-Assistant and have carried out a whole series of test flights, but to no avail. Records are not anywhere to be found, and a "Clear Logs" button does not exist either.
Nevertheless, I will give V4.0.6 a try! But to be perfectly honest, Tomáš, given how buggy your software keeps turning out to be, I’d rather not connect my transmitter to it. ;)
Regards Philipp
Phil S.
"SPIRIT.bin" file info as shown in "DEVICES" on my DS-12:
Size 205.712 Bytes, created on monday, 15/06/2026, 09:40:28
Correct?
Regards Philipp
Then please do not try version 4.0.6 and wait for official release.
I hope you have not enabled 500hz logging when using 4.0.5 firmware and then downgraded your Spirit firmware.
Instead of hours of trying you can simply ask.
Phil S.
You want to say that's why logging does not start with 4.0.4? Does 4.0.4 generally not work with maximum frequency? The solution would be upgrade to 4.0.5, then reduce to lower than 500Hz, then down to 4.0.4 again? By the way, every step I made was recommended by your AI-Assistant ... 8-)
And what about the loss of control? A version mismatch between firmware and integration should be ruled out as the cause I suppose?
Regards Philipp
Firmware 4.0.4 has maximum logging frequency 50Hz so if you upgrade to 4.0.5, then set it to 500Hz and downgrade you will end up with invalid configuration.
Downgrading has no good purpose, since 4.0.5 has higher safety margin because of new loop watchdog.
We can't still rule out version mismatch of the BIN file. We are unable to reproduce this problem with any of configuration yet. Unfortunnately with no additional detail it is hard to guess, but it is recommended to use more recent firmware than old one if you were playing with new logging features.
AI Assistant is not developer of the system 8-) Our next iteration of AI assistant will improve in this area.
Phil S.
But you consider it safe matching firmware 4.0.5 with integration 4.0.4?
And how could we get "additional details" to improve our ability making "educated guesses" a little more? ;)
Regards Philipp
For example anything about your setup and your settings file. From your description we only know you have GTR, using 4.0.4 firmware and it suddenly started to loss of control after pressing Save Settings in the integration menu.
Since 4.0.4 is months old and is used by so many pilots worldwide the most probable reason is something specific in your setup/settings. So something that happened in between after hundreds of flights and the issue occurance is the most likely also reason. If it worked for so long time and now you can see this odd behavior then it is enough to recall what you did right before it started to happen.
I would also verify failsafe settings.
Phil S.
The last couple of months I ran on V4.0.3. The only thing I did just a few flights before the problem occured was updating to V4.0.4 (using Windows software V4.0.5).
Failsafe is verified several times. Or rather, it had to be reset several times. This is because the Spirit-integrated Jeti RX does not provide any means to check the settings. The only option is to remove all the rotor blades, run the heli up and switch off the TX.
Let me ask again: Do you see any risk matching Spirit firmware 4.0.5 with Jeti integration 4.0.4r2?
Regards Philipp
Zero risk
