Jeti DS16, R9 Receiver and Spirit...?
Franky13
hi thomas!
can you help me with the right connection with DS16 and a Jeti R9 receiver?
with the DS16 and the Jeti RSat2 it goes away!
not with the R9 receiver ...
as I have the spirit, DS16 and R9 connect?
greeting frank
dslraser
you can connect the receiver in few ways - PWM, PPM, UDI or EX Bus.
Which one do you want?
For UDI you can use SAT port, for EX Bus EXT port. Be sure your receiver is updated else EX Bus will not work probably.
For UDI you have to select SRXL/SUMD receiver type.
Franky13
ok,
I have everything connected as recommended.
UDI set in the transmitter, set in spirit to SRXL / SUMD, then RUD put on the SAT in the receiver, BEC from Kosmik plugged into the AUX from Spirit.
I have no servo motion ... ???
What firmware version is in the receiver?
UDI should work out of the box with default Jeti settings.
I can try R9 EX receiver with Jeti + UDI in few minutes.
Franky13
It is the 3.23 Version.
Franky13
in my diabolo I have installed the RSat2.
no problem!
For me R9 EX is working out of the box.
Only you have to do is to configure UDI serial connection in your receiver. Then you should see it is running on SAT port.
And finally configure SRXL/SUMD receiver type and save the settings.
Then, after restart all should work.
