Page 2 of 3
Re: 3blade head and spirit possible??
Posted: Wed 28. Oct 2015 10:18:39
Great, so in this case, you should increase Governor Response first.
If you feel that it does not make any difference, try to increase Max. value in the Throttle Range, for example by 5-10 points.
Posted: Wed 28. Oct 2015 10:27:19
by Joeri_Plees
ZeXx86 wrote:Great, so in this case, you should increase Governor Response first.
I have the governor response on max and the difference between the max and default isn't noticeable.
And have you a photo of what you mean with throttle range please I doesn't have the software right now maybe I now if I see what you mean what my value is.
Verstuurd vanaf mijn SM-N910F met Tapatalk
Posted: Wed 28. Oct 2015 10:33:05
In this case, the problem is most probably in the Throttle Range - Max. parameter.
You can try to increase it from 100 to for example 110. Then you should feel difference.
Posted: Wed 28. Oct 2015 10:35:17
by Joeri_Plees
Oké I understand I gonna try that fast as possible thanks man! Hopefully it works I love the unit on its own and using the esc governor but because the hobbywing governor is s**t I must use the spirit for it so hopefully it's gonna works otherwise I must by a new esc
Posted: Wed 28. Oct 2015 12:30:27
by Joeri_Plees
Increase is from 100 to 110 and negative also from -100 to -110 or only the positive side?
Posted: Wed 28. Oct 2015 12:45:43
No, only 100 to 110. If you will not notice difference, than you can try 120.
Posted: Wed 28. Oct 2015 12:45:59
by Joeri_Plees
Oké thanks
Posted: Thu 29. Oct 2015 9:20:36
by Joeri_Plees
It's help a little with the 110 setting but not very much... Try 120 now? Or what
Posted: Fri 30. Oct 2015 8:19:37
Yes, you can increase it to 120 until you will hear that there will be excess overspeeding - after some hard manouver RPM will drop slowly from the highest to the requested.
Posted: Sun 01. Nov 2015 14:29:21
by Joeri_Plees
Nope it doesn't work I gonna buy a good esc with a good governor that's the only solution I think
