Page 2 of 2
Re: First English Thread
Posted: Fri 01. Aug 2014 0:18:15
by Jman841
Awesome! thank you!
Is there anyway to power the BT Unit from the FBL itself or does it require an additional BEC?
On my larger heli's it is no issue, but for my Gaui X3 I just use the BEC on the ESC so it has only one power lead.
Posted: Fri 01. Aug 2014 7:20:09
by pkotatko
In SYS port is NOT a power supply. That means, BT unit need some power connection. Somewhere on board. But, don`t let the BT unit run during the flight. Better to switch it off. Just to be safe.
Posted: Fri 01. Aug 2014 19:38:01
by Jman841
ok awesome,
I will use an open port that has power to power it. Thanks again! Can not wait on it's arrival! Will be buying many more once I am comfortable with it's function!
Posted: Tue 05. Aug 2014 6:12:53
by RC Man
Hey Tomas,
How are you doing man.
I was just wondering if you need a Dealer in Germany
I have a small shop here, and think I could sell lots of FBL units for you.
Could you send me a pm or a email about this, if your interested that is.
Keep up the good work.
Frank
Posted: Tue 05. Aug 2014 9:44:18
Hello Frank!
Thank you very much, I'll write you PM.
Posted: Sat 09. Aug 2014 17:23:25
Finally BT scheme in the attachement
Posted: Sat 09. Aug 2014 20:21:24
by Jman841
Awesome!
I am considering switching over to Taranis so if I do I will go the sbus route, is there anywhere else I can purchase the sbus adapter? preferably in the states so it is quick shipping?
Posted: Sat 09. Aug 2014 23:44:02
by Jman841
Also, Can I have 2 inputs for the BEC and 2 Sat rx's? For now I am going to run the DSMX sat's but on my Atom 500 the ESC BEC (Hobbywing Platinum V3 100amp) Has 2 leads for the BEC to help with the high demand HV servos. Is it possible to run both of those leads and the second DSMX Sat with the adapter?
Posted: Sun 10. Aug 2014 9:28:23
I think somebody in HF thread mentioned eshop in USA, but you can buy it directly from Tarot eshop, hobbyking or ebay.
Or you can wait one week, then we should sell our own adapters for both S-Bus and Spektrum.
You can connect two leads, second with Y cable to for example AUX position. But I guess one is OK for mini servos.
Your hobbywing is suitable even for 550 size helicopters.
