Page 2 of 3
Re: FASSTest 18ch telemetry shows no ROXXY
Posted: Mon 18. Sep 2017 3:21:09
by RedJacket
ZeXx86 wrote:As far as I have found the ROXXY ESC should be present in the older firmwares as ESC.
It is strange they have removed it just from this yet there will be also still users with these ESCs.
You can try to reset telemetry data. Maybe it will be automatically detected.
I've tried reloading. It won't work.
For the reason that Futaba removed it (temporarily I guess), we may guess by this document.
http://j-log.eu/wp-content/uploads/S32/ ... anceEN.pdf (search ROXXY ESC )
I've asked them to fix it through local dealer.
Posted: Wed 20. Sep 2017 15:57:10
by RedJacket
I found http://www.ripmax.de/software-downloads ... nliste.pdf
And this http://www.ripmax.de/ripmax-roxxy-smart ... re=default
So it says this ESC supposed to be registered. (luckily 14SG / 18MZ has pre-registred ID)
Is here any german friend who can try to register this real "ESC" and use "spirit pro" using that ID just for fun?
Posted: Wed 20. Sep 2017 16:03:42
Thank you for the documents.
If it will be not possible to solve the problem, we will have to change telemetry to work probably as Kontronik sensor.
Posted: Thu 21. Sep 2017 12:33:17
by RedJacket
ZeXx86 wrote:Thank you for the documents.
That will solve all the problem I think.
Posted: Tue 03. Oct 2017 10:07:29
This week it should be rewritten for another sensor so all problems should be solved.
We can then share the updated firmware.
Posted: Tue 03. Oct 2017 13:40:00
by RedJacket
ZeXx86 wrote:This week it should be rewritten for another sensor so all problems should be solved.
Thank you for the support.
Posted: Sat 07. Oct 2017 10:06:44
I would like to ask you, if you can try to check fot ROXXY ESC at other slots in your radio.
In Futaba for some slots only selected sensors are available.
So for example also in 14SG you can see ROXXY ESC for SLOT 1 but KONTRONIK and CASTLE-TL0 is not there.
It is similar for other slots. Only for SLOT 8 KONTRONIK and other sensors are there.
I recommend to check especially SLOT 5, 6, 7 and 8.
Posted: Sat 07. Oct 2017 13:49:57
by RedJacket
ZeXx86 wrote:I would like to ask you, if you can try to check fot ROXXY ESC at other slots in your radio.
Thomas,
I checked all 31 slots and found no roxxy esc. Another user confirmed.
To make it easier, I am uploading some photos.
KH
Sensors menu and slot 5 6 7 8 photos.
Posted: Sat 07. Oct 2017 13:51:48
Great, thank you very much.
Today I will upload firmware with support for Kontronik sensor :)
Posted: Sat 07. Oct 2017 14:23:07
Please download this firmware:
http://spirit-system.com/dl/fw//spirit-fw-2.4.6.4df
Delete all Sensors and set KONTRONIK ESC at SLOT 8.
Then all should work :)
