Info how work SPM4649T Telemetry
Pino74
OK made the connection now works, the temp grades are exact those of the esc and also the volt.ma I see the line / motor fields and bec empty. Is this normal? as photos Thanks
Yes, this is normal with this ESC. You can get additional telemetry data by connecting a wire directly to the SPM4649T receiver.
Campbell
Yes. You won't get any bec data and motor data will only appear as you spool up the heli.
Well done.
Pino74
Ok Good
Campbell you can explain me that u mean for setting mah alarm?i dont see this screen or voice in m radio or esc telemetry.Thanks
Note: My hely when i shot photo from radio,it was on,why the engine data were still?
Pino74
ZeXx86 wrote:Yes, this is normal with this ESC. You can get additional telemetry data by connecting a wire directly to the SPM4649T receiver.
Thanks ZeXx86
what do you mean by wire directly?where , in which port on spm4649? other additional sensors? where you add cables to spm 4649 t? I have only one free port now on spm 4649, the jst 2 poles/where u can connect laps/V batt
Yes, this is what I have meant.
Pino74
Ok Perfect, then I feel confirmed that for now on the 2.4.3 firmware without additional sensors but only with the 4649 spm, and with compatible ESC, the only data you can receive are:
1) Rpm (from esc)
2) Volt (from esc)
3) Temp Fet (from Esc)
The motor data 0.0A and 0% output are always stopped.
Pino74
Perfect now all clear!!!
Last question the gps when it will be released? and if possible one day find and where quality cables already crimped Jr / futaba to jst, I ask why on heli small size, the additional links plug/conversion take up space, when use microspirit.
there is link my video
of my heli (OLD TREX 250 SE)working perfectly with microspirit both mechanical flybar, and dfc (now) AS PHOTOS
https://www.youtube.com/watch?v=7O5oVNSFjhw
