[SOLVED] srxl2 AR6610T
latjo-k
Any progress?
we have found the issue with certain AR full size receivers. I believe firmware that has fix for them will be available on monday.
Also we are preparing guide for wiring.
latjo-k
I think its a diffrent,we can always count on Tomas and heas team that they always do ther best to satified
our needs.
I wonder if any other supplyer of fbl units put in so mutch effort as they do.
If we heli pilots stick to Spirit ther is no limit what he and heas team can bring out for us in the future.
//Lars
tfmcnellist
looking forward to the revision.
we have solved the problems with firmware update.
All SRXL2 receivers should work now.
Please flash this firmware:
http://spirit-system.com/dl/fw//spirit-fw-2.8.1.4df
Wiring diagram for AR6610T will be available tomorrow. For this receiver normal JETI Integration cable is needed (or you can make the cable at home).
latjo-k
ZeXx86 wrote:Hello,
Hi Tomas
I have tested the new firmware and there is some issues.
Its sems impossible to get throttle out to work,in diagnostik window(ch1)it moves from 0-100% but the esc is not responding.Iwent back to spm4649t just for testing and the esc starts up fine,whith the same settings
in unit (i only Changes recivertype).
And channel 7 bankswitching and 8 rescue dont respond(50%)at all in diagnostik window,same settings in tx DX9 as whith spm4649t.It sems that AR6610T only trasfer 6 channels.
Hope you can fix the problems or tell me if i doing something wrong.
Everything else works perfekt.
//Lars
Sorry for the troubles.
After inspection we have found what is wrong.
Now also throttle from the unit will work.
http://spirit-system.com/dl/fw//spirit-fw-2.8.2.4df
You can also use Throttle output directly from the receiver.
latjo-k
ZeXx86 wrote:Sorry for the troubles.
Hi
now trottle works,but what abaut ch7 and 8?
Ch5 gyro,it looks like it is reversed.The monitor in tx shows 70% in diagnostiks it shows -63
//Lars
tfmcnellist
This was one of my original question, will all 8 channels work?
tfmcnellist
Hi
//Lars
Any update to this question?
