Page 2 of 5
Re: uSpirit severe tail wag - motorized tail
Posted: Thu 22. Oct 2020 15:42:20
by daniel_i
Many thanks man!
Did I get you right?
Posted: Thu 22. Oct 2020 15:48:53
by fassla
correct, you do not need ground for tail signal on any of the available FBL systems (JST2 is sufficient to hold signal cable)
Posted: Fri 23. Oct 2020 11:32:57
by daniel_i
fassla wrote:I can see you have rudder frequency 50Hz, switch to 333Hz, and delay to 0.
Hi @fassla I didn’t get you with rudder frequency, where is this setup? You actually mean pirouette consistency?
Posted: Fri 23. Oct 2020 11:55:29
by daniel_i
Huge thanks @fassla
Managed to get this thing in air. Btw are you in spirit team or ...?
https://youtu.be/04BevZAqBsE
Now of course tail does a bounce back and cyclic has a bit of shaking but I think this should be addressable through the parameters.
Posted: Fri 23. Oct 2020 13:46:22
by fassla
happy to see you are up in the air
and, No I'm not in spirit team
Posted: Sat 24. Oct 2020 22:32:45
by daniel_i
fassla wrote:happy to see you are up in the air
Thanks! tail and cyclic are fine.
I am now trying to figure out why I don`t get the current RPM value through that MTX pin.
I plugged that into P pin of P/E/A port of uSpirit and I get no output.
Also I counted 24 poles in the sunnysky motor => 12 value in sensing divider, right?
Posted: Sun 25. Oct 2020 7:15:46
by HeliMLM
did you plug into middle pin? i would say the manual could be misleading in that point...it says: „μSpirit - P pin - pin in the middle of P/E/A port“… but maybe i am wrong… do not know microSpirit.
Posted: Sun 25. Oct 2020 9:29:50
by fassla
I think Tomas needs to have a look on it. Neither P nor E on uSpirit is delivering a RPM value
Posted: Sun 25. Oct 2020 9:31:24
by daniel_i
fassla wrote:I think Tomas needs to have a look on it.
Okay, but is your setup reading the current RPM?
Posted: Sun 25. Oct 2020 9:33:02
by fassla
for some reason I use the OMP ESC on a different FBL system....and there it is working as I showed to you
