Spirit2 System with ELRS rx
nmsantarelli
ZeXx86 wrote:ELRS does not offer this diagnostic.
Diagnostic works with Lua script when using SPORT, FPORT or FBUS with both OpenTX and EdgeTX.
Each protocol and receiver has own limitations, ELRS have probably the biggest limitations from any available protocol. But it is well marketed so popular these days.
Forgive my ignorance,
with the Spirit2, I can only get diagnostics (adjusting the minimum and maximum values and counter-sticks) by connecting the USB interface to the PC.
I have the WiFi interface that connects to the SYS port; the app displays all the parameters (even the ones I didn't know), but no stick diagnostics.
I assume that with the USB interface, the refresh rate between Spirit2 and PC is realtime, while in all other cases (WiFi, Bluetooth, Lua, etc.) it's something like this:
- Query and read all values and display them on the radio/app/etc.
- Via Radio/App/etc., I manipulate a value and, with the SAVE command, send all the variables back to Spirit2 with the old and new values.
What I said is my impression.
nmsantarelli
Therefore, the Spirit2 cannot have diagnostics since the receiver connects directly to the SYS port.
OK
franz88
https://youtu.be/aqCz9X8bP4s?si=n8rDj7-Hxy45KIKM
Use subtitle translate automatic
For helicopter you can use the channel full range (otherwise the servos they will only have limited positions)
nmsantarelli
franz88 wrote:
nmsantarelli wrote:
franz88 wrote:you have edge tx?
it s possible integration with edge tx ?
My radio (Radiomaster Boxer) is edgeTX and all the setup parameters appear but not the diagnostics.
and what did you download from the site?
in the site there is integration:
spektrum
jeti model
open tx
graupner hot
ethos
I'm attaching a photo for you
i have tx16s with edge tx and I want integration too spirit software in my radio but i use multimodule and no elrs
When using TX-RX ELRS, go to SYS and search for ExpressLRS (script). Run the script and the TX ELRS parameters will appear. Scroll to the bottom and find "Other device." Select it and two items will open: One is the RX name and the other is Spirit. Click on Spirit and you will find all the FC parameters.
