TB70 Vibrations
senaka
davehour wrote:Just curious if this model can be flown with those vibrations.
I flew for months with high vibrations until I measured the levels just out of curiosity. Not saying that it’s ok as it depends on how much vibrations present and also the wear on bearings. Even the tightness of the tail belt or the tail blade can can have an effect on vibrations. I’m flying with a somewhat loose tail blades that I can move with a finger. Too tight then I get higher vibrations which for the life out of me cannot solve after balancing everything.
Someone please correct me, vibrations can confuse the accelerometers used for self leveling which is also a part of rescue.
davehour
What model do you have?
Yes, too much vibrations affect rescue.
davehour
We should keep in mind the tail belt should run smoother and jump less inside the boom when it’s loaded with the tail blades.
senaka
davehour wrote:What model do you have?
I fly a kraken 580
davehour
Instead of flying this new model with the vibrations detected by the Spectrum Analyzer, I started systematic approach to isolate the vibrations, as suggested by Senaka.
I disconnected the main belt to run the motor and pulley only, and this is what I got.
Seems the next thing to do is to test with another motor.
Vibrations running the motor and pulley only.
davehour
Installed another motor from a heli which has OK vibrations in all axes and at all head speeds, running the motor disengaged to have equal testing conditions.
Was surprising to find the TB70 showed the same vibrations pattern as with the original motor.
Conclusion:
The vibrations detected in the TB70 are inherent.
Let see how the model does in actual flight.
senaka
Try increasing and decreasing the rpm by 100 rpm’s at a time while you’re there to see if it makes a difference. Also the pinion may have two sizes of grub screws where the longer one goes in where you have the indent on the motor shaft.
davehour
I can sweep the headspeeds I want to use and choose the quietiest ones although headspeed will vary doing maneuvers.
When I installed the other motor, I kept its pinion which tested OK in the other frame.
